pugcoin
Nov 08, 2020Tutor
Circle 1st Gen App (2.1.10) arbitrarily blocking websites on RBR50 with 3x RBS50 (firmware 2.7.1.60)
Hi I upgraded our Orbi RBK50 system (2.7.1.60) and Circle 1st Gen (2.1.10) to latest firmware versions to address intermittent web disconnections. It has not fixed the problem. Disabling Circle fixes ...
- Nov 12, 2020Hi thanks. I did upgrade to the latest firmware 2.7.1.60 for the router and satellites. Bad connections with Circle enabled; works perfectly when disabled.
I will try router factory reset.
Christian_R
Nov 12, 2020NETGEAR Employee Retired
Hello users,
I would recommend checking to see if your device is due for a firmware update. After a firmware update, you may try factory resetting the router and running through the setup assistant again along with reinstalling the Orbi/Circle app.
Christian
L3ftDr1ft
Nov 16, 2020Initiate
Manually updating to RBR firmware 2.7.1.60 (and RBS 2.7.1.60), + a reset of all devices seems to have largely resolved the issue. This firmware did not automatically update via the app, I had to download and install via the webUI.
I've still gotten intermittent false Circle blocks, but they are resolved by reloading hte page, and have seemed to dwindle in frequency over the past 3 day.
