Jack1234
Jan 22, 2021Aspirant
Circle 1st Generation app no longer track netflix usage
My Circle 1st gen app no longer tracks the Netflix usage. All the other functionalities are working. For e.g. when I use youtube, the usage is correctly reported. But the Netflix usage is not counted across all profiles. I have checked under the Filter settings and Netflix is set to "allowed" and NOT "unmanaged". This problem only started happening in the last 2 weeks or so. Not sure whether it is a bug? Does anyone have similar issues?
- Christian_RNETGEAR Employee Retired
Hello Jack1234,
I would recommend checking out the article below for missing usage/history issues.
Christian
- Jack1234Aspirant
Thanks for the reply. Mine is a Cicle build into the netgear orbi router. The link doesn't have anything special for me. Also youtube and other services are tracked correctly. My issue is only with Netflix.
