Hos9876's avatar
Hos9876
Circle as it keeps asking me for passcode which i never receive
Hi - have. new phone and can not get into Circle as it keeps asking me for. passcode which i never receive. Tried ll the other suggestions on circle help but without by luck.
Hoss
  • Hi - i done a self fix on this.
    1. on the netgear router settings turn off circle parental controls and “upgrade” to netgear parental controls
    2. reboot router
    3. Launch app and select parent controls
    4. follow prompts
    means you get rid of circle and can at least start again
