Torque1's avatar
Torque1
Circle breaks WiFi calling
When circle is enabled, and the profile assigned to a device is not none, WiFi calling does not work. It simply won’t connect. This is tested using a UK three and UK O2 SIM card. If the Circle profile is changed to none (no filtering) it connects straight away. In reviewing the history from the Circle app no domains are listed as being blocked. I can see other posts reporting the same issue, but none have a resolution or even acknowledgement of this issue from Netgear. I have tried the adult profile with VPN and Proxies allowed as per a Circle tech note, this does not work.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Torque1,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
    • Torque1's avatar
      Torque1
      I purchased the device last November so it’s outside the support period. It has had the issue since new, but I didn’t realise it was circle causing it until I found time to properly diagnose.
      • Manxviking's avatar
        Manxviking
        Tutor
        i have had a similar issue. Spent weeks trying to understand why wifi calling only works intermittently, often having to wait several hours for the iphone SE to pickup wifi calling despite it being connected to a strong signal. Disabled Circle and it connects immediately. The circle profile had VPN etc enabled. It seems that this is a known issue for sometime but Netgear has yet to address it. The whole point of having the orbi was for the parental controls. Come on Netgear, sort this out.
