tcomp
Mar 29, 2021Star
Circle Kills All Internet
Hi everyone!
I've beeen using the RBR20 and Circle for a long time. It's been working great. I recently upgraded to V2.6.2.104 firmware maybe about 2 weeks ago. Things were working normally.
All of a sudden this morning all internet to everything in the house stops working. After investigating, I find out actual internet pings are OK, but all DNS is failing to resolve. After mucking about for a while, I determine that if I disable Circle, everything works normally. Turning Circle on, kills all DNS in the house.
When circle is on, I can't even connect to it using the Circle app on my phone (that's the parent/manager account). Circle app just spins for a while and then says it can't find a circle.
Not really sure what I should do here? I can't even get into the circle management, so unclear what the best next steps are. I've attempted rebooting everything, which does not solve the issue.
Any insight/help is appreciated!
This seems to be a lot like this previous thread:
However, that one seems to be solved by a firmware update, so maybe in the last release it was broken somehow? The previous problem was fixed later last year...
- npadleyInitiate
Sending a quick reply to confirm that I'm another RBR20 user that is having the exact same problem. While I don't have any solutions, I figured I'd confirm that you are not the only one.
- Christian_RNETGEAR Employee Retired
Hello tcomp & npadley,
May you revert to the previous firmware version and let me know if your issue persists.
https://kb.netgear.com/000062432/RBR20-Firmware-Version-2-6-1-36
Christian
Yep - I will try that today and see what happens.
Christian_R - what about the satellites? I only see the RBR firmware there in the link you gave me. Can I leave the satellites on the newer firmware or should I adjust somehow?
- HenrytnguyenAspirantI got the same problem this morning too.
So, how do you disable the circle app?
So, how do you disable the circle app?It's in Advanced>Security>Parental Controls
- HenrytnguyenAspirantThanks, will do
- Rob111Aspirant
I am having same issue when I enable parental controls. No idea how to fix this
Rob111 wrote:I am having same issue when I enable parental controls. No idea how to fix this
Do you mean when you disable it? So far, from others, it seems that turning off parental controls/circle at least gets your internet going again.
- Rob111Aspirant
When I disable the parental controls internet works, no issue there, I need my parental controls back on
I can confirm that I did the suggested downgrade that Christian_R mentioned, and I am up and running again, with Circle/Parental Controls turned back on, and it's working. Seems like something in the most recent update is probably not playing well with Circle.
