SA2003
Jan 20, 2023Aspirant
Circle passcode and remote access - Orbi RBR50
Dear team, Haveing issues in getting the Circle passcode, unable to use the remote access to control the Circle from outside home and not receiving any notification of new devices joining my home n...
SA2003
Jan 24, 2023Aspirant
Thanks for the reply .. I can see the passcode now however the remote access issue still exist, is there away to fix it.
Jan 24, 2023Guru - Experienced User
You'll need to submit a bug report:
Or make contact with NG support:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
