mpiekny
Jan 09, 2019Aspirant
Circle Setup
App downloaded on my iPhone won’t recognize my router. Help.
DexterJB
Jan 10, 2019NETGEAR Moderator
Hi mpiekny,
Welcome to the community!
1. Please make sure that you have followed the steps linked below:
https://kb.netgear.com/000038871/
2. What is the firmware version of the router?
3. Please try using another device if the issue will persist.
4. You can try re-installing the app.
Dexter
Community Team
DexterJB
Jan 14, 2019NETGEAR Moderator
Hi mpiekny,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- mpieknyJan 15, 2019AspirantNo progress, Dexter. Firmware is up to date. Cycling power doesn’t help. Genie and remote control work fine. Need to fix this week or will return. That’ll be the second return. irst time was because Model did not support Circle.
- DexterJBJan 16, 2019NETGEAR Moderator
- mpieknyJan 16, 2019AspirantReceived and replied.
