mpiekny
Jan 09, 2019Aspirant
Circle Setup
App downloaded on my iPhone won’t recognize my router. Help.
DexterJB
Jan 14, 2019NETGEAR Moderator
Hi mpiekny,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
mpiekny
Jan 15, 2019Aspirant
No progress, Dexter. Firmware is up to date. Cycling power doesn’t help. Genie and remote control work fine. Need to fix this week or will return. That’ll be the second return. irst time was because Model did not support Circle.
