Francozen
Mar 11, 2019Aspirant
Circle time zone messup ?
Hi.
My kid was complaining that her internet access was shutdown while it shouldn't have been.
I noticed that the logs were off by 1.5 hours so I double checked the timezone setup on the R7000 it...
- Mar 15, 2019
Thanks for your help.
It turned out to be related to the authorization of a new phone on which the time was not set correctly, as explained in https://support.meetcircle.com/hc/en-us/articles/115001381952-How-Do-I-Set-Circle-s-Timezone-Settings-
I re-installed circle on said phone, and re-authorized it while the time was set properly. It fixed the problem.
DexterJB
Mar 13, 2019NETGEAR Moderator
Hi Francozen,
Welcome to the community!
1. Have you tried doing a quick power cycle (turn off and on) on the router?
2. Have you tried disabling and enabling Circle?
Dexter
Community Team
- FrancozenMar 15, 2019Aspirant
- DexterJBMar 18, 2019NETGEAR Moderator
Hi,
Thank you for the update and confirmation. Glad to know you got it working!
Dexter
Community Team
