Nomticus
Jan 10, 2019Aspirant
Circle with Disney App activation loop
I have an Orbi WiFi mesh router with two satellites. Upon first configuring the device, I activated Circle for Parental Controls. All of that worked just fine. However, after doing so I got a new iPh...
DexterJB
Jan 10, 2019NETGEAR Moderator
Hi Nomticus,
Welcome to the community!
You can try following the steps on the link below.
Dexter
Community Team
- DexterJBJan 14, 2019NETGEAR Moderator
Hi Nomticus,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- NomticusJan 15, 2019Aspirant
Not anymore but only because I reset the router to factory defaults and set everything back up again. It was a real pain since I had already done all this before. The help guide was actually of no help since it required the relationship to be setup and I couldn't get past activating the service from within the Circle app.
Thanks anyway.
