Nomticus
Jan 10, 2019Aspirant
Circle with Disney App activation loop
I have an Orbi WiFi mesh router with two satellites. Upon first configuring the device, I activated Circle for Parental Controls. All of that worked just fine. However, after doing so I got a new iPh...
DexterJB
Jan 10, 2019NETGEAR Moderator
Hi Nomticus,
Welcome to the community!
You can try following the steps on the link below.
Dexter
Community Team
DexterJB
Jan 14, 2019NETGEAR Moderator
Hi Nomticus,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- NomticusJan 15, 2019Aspirant
Not anymore but only because I reset the router to factory defaults and set everything back up again. It was a real pain since I had already done all this before. The help guide was actually of no help since it required the relationship to be setup and I couldn't get past activating the service from within the Circle app.
Thanks anyway.
