SilverWinterSky
Mar 27, 2021Aspirant
Circle002 certificate issue
My sons Macbook is suddenly unuseable on our Orbi wireless network, showing the dreaded “This connection is not private” error on all browsers.
The associated certificate is Circle002.
I’ve tried disabling Circle. I’ve tried deleting the certificate. No progress.
If anyone can offer any help on this I’d be so grateful. Thank you in advance.
- Christian_RNETGEAR Employee Retired
Hello SilverWinterSky,
May you forget the WiFi network on your son's Macbook and reconnect to the network.
Christian
- SilverWinterSkyAspirant
Thank you. I will try what you suggest.
Can you explain why it might help?
This is to help isolate the root cause of the issue you're experiencing since the Macbook seems to be the only device you're having issues with.
Christian
