dtoepoel's avatar
dtoepoel
Disney Circle is blocking Ring Doorbell Pro Chime to function/connect to wifi
Hi,
I have an Orbi RBR50 and two satellites, with Netgear Armor enabled, along with a Ring Pro doorbell and 2 Chimes that have been working fine.
That is, until I enabled Disney Circle on the Orbi.
The chimes lost connection and I could not get them to connect anymore. A factory reset of both chimes didn't work either. I made sure I had set all default devices to 'unfiltered' in Disney Circle to try and make sure it would not interfere in blocking them.
Not until I noticed this thread and actually went ahead and disabled Disney Circle could I get the chimes to reconnect again.
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-Circle-is-blocking-Ring-Doorbell-Pro/td-p/1677674
The Ring Doorbell Pro itself kept working fine with Circle enabled, the doorbell itself isn't the problem. (the Ring app keeps working just fine as well) ; it's just without the Chimes, you don't hear the doorbell in the house.
I really would like to enable Circle though. Any idea on how to further troubleshoot or mitigate this issue?
Kind Regards
/Dennis
