stevepixels
Nov 05, 2018Guide
Disney circle passcode reset text not receiving
Got a new iphone and didnt think anything about signing out of circle on old phone which has now been reset. Trying to get myself back into my circle and ask for text message to send code but nothing...
orbisteve
Apr 11, 2020Aspirant
Sorry to disappoint everyone but at least in my case even the four digit passcode I was sent by the otherwise very helpful moderators didn't work. I had to do a complete factory reset and start over with configuring everything. I hope others will have more luck.
el_el
Jun 01, 2020Aspirant
Running into the same issue....feel your pain.
Wondering if after a factory reset, the passcode reset via SMS is working ? My fear is that I will have to be doing factory resets every so often for all eternity. At least it looks like they are working on a fw https://status.netgear.com/
I used to have a netgear nighthawk and the SMS reset system worked fine....
Another anoying thing is i can't find my system from the Model drop down... (RBK44 — Orbi AC2200 Tri-band WiFi System)
