akomaha04's avatar
akomaha04
Follower
Aug 09, 2018
Disney Circle Passcode Reset
Is there a way to reset the circle passcode?  I'm talking about the 4 digit passcode that's required when you initially install the app.  My son installed the app on his phone and grabbed the passcod...
  • DexterJB's avatar
    DexterJB
    Aug 20, 2018
    Hi akomaha04,
    Please try the following steps:
    1. Uninstall the Circle App on your kid’s phone
    2. Reinstall Circle on your device
    3. Select the option "I’m the only Circle Admin" and a new passcode should be sent on your mobile via SMS
    4. Change the security on your phone and setup pin lock to ensure that your kid won’t acquire the code again
    This link as well as this link may help.
    Dexter
    Community Team
