akomaha04
Aug 09, 2018Follower
Disney Circle Passcode Reset
Is there a way to reset the circle passcode? I'm talking about the 4 digit passcode that's required when you initially install the app. My son installed the app on his phone and grabbed the passcod...
- Aug 20, 2018
Hi akomaha04,
Please try the following steps:
- Uninstall the Circle App on your kid’s phone
- Reinstall Circle on your device
- Select the option "I’m the only Circle Admin" and a new passcode should be sent on your mobile via SMS
- Change the security on your phone and setup pin lock to ensure that your kid won’t acquire the code again
This link as well as this link may help.
Dexter
Community Team
DexterJB
Aug 27, 2018NETGEAR Moderator
Hi akomaha04,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Slick22
Sep 13, 2018Initiate
I have the same problem. But I never receive a text with a new passcode. I need to reset my phone number I guess?
- lightning77Sep 24, 2018Tutor
I have same problem with a twist
Circle App sees the router but I can't reset PIN because SMSs are not comming thropu.
Is there a way to receive code through email?
forgot to list model: R7000 / AC1900
