Kap10
Nov 21, 2016Follower
Disney Circle
Is Orbi compatible with Disney Circle?
- Dec 19, 2017
Hi all,
Circle support for Orbi will be available in future updates but no ETA is available.
Dexter
Community Team
DexterJB
Jul 30, 2017NETGEAR Moderator
Hi all,
All our routers are compatible and will work with the Circle box.
We earlier this week released on just Nighthawk AC2300 Smart WiFi Router [R7000P] a new firmware that integrates the Circle functionality, so that customers can manage internet content and time across all their devices without the need for the separate Circle Box.
Dexter
Community Team
rybickirj
Aug 07, 2017Aspirant
I was wondering when will they?, or have they already released the firmware update with the circle with Disney for the R7500v2?? or can i somehow update my firmware with the one that is from the R7000P??
if I would have known that the R7000P (AC2300)was going to come out with the Circle app i would have bought that one instead of my R7500v2(AC2350)
the two routers are not all that differnt from each other that i can see.. i dont see why the firmware from the one wont work on the other... makes me wonder why they have differnt firmware to begin with..
- DexterJBSep 21, 2017NETGEAR Moderator
Hi rybickirj,
As it stands, the R7500v2 is not supported by the Circle app. Different router models have different firmware since they differ hardware wise.
Dexter
Community Team
- VenosaurOct 16, 2017Tutor
hello,
I would like to ask about Circle Box. Do You think that is the best way to protect childrens in net. Of course that Premium looks so nice. But how this Circle Box for example in R7000 influance on routers work.
- DexterJBOct 17, 2017NETGEAR Moderator
Hi Venosaur,
The links below will give you an overview on the features and may help you decide.
https://kb.netgear.com/000038873/What-is-Circle-and-why-should-I-use-it-with-my-NETGEAR-router
http://www.netgear.com/landings/circle/
Dexter
Community Team
