1sharpfamily
Jan 05, 2018Follower
Enable for Circle with Disney missing on R7000P
I had previously updated the firmware shortly after original installation before attempting to setup Circle with Disney. Following the instructions in the manual page 39-40, for "Enable Circle With D...
- Jan 11, 2018
Hi 1sharpfamily,
On the router UI, you can go to Basic > Parental Controls > toggle Circle with Disney. Or you may use the Circle App using the steps linked below.
https://kb.netgear.com/000038870/
Dexter
Community Team
DexterJB
Feb 05, 2018NETGEAR Moderator
Hi 1sharpfamily,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
