innerbooty
Jul 06, 2020Tutor
Netgear Circle sucks. Support sucks. I want my money back...
I've only been using Circle for about two weeks. My big mistake was paying for a year in advance, and then seeing the fine print saying that if you paid via Apple through the App that they can't refu...
schumaku
Jul 06, 2020Guru - Experienced User
innerbooty wrote:I've only been using Circle for about two weeks. My big mistake was paying for a year in advance, and then seeing the fine print saying that if you paid via Apple through the App that they can't refund your money.
That's caused mostly the wonderful T&C in place by Apple (and Google FWIW).
You might start here -> Request a refund for apps or content that you bought from Apple
innerbooty wrote:Bedtime doesn't work for video games, which defeats the whole purpose of getting the useless app in the first place. No one has offered any helpful advice for this.
-> Contact Circle on NETGEAR Support ... call them up on the number indicated.
"The agents there will help you know whether you are seeing an issue with your router or an issue with your Circle account, and their technical support is fully trained on the Circle software embedded in your device. Make sure you mention that the product you are using is Circle on NETGEAR, and let them know your purchase date is the most recent renewal date for your subscription."
innerbooty wrote:Also, I love how ONLY if you have Netgear with Circle do you need to pay for support. Paid support?
Bet you have contacted Netgear's standard consumer support instead of the dedicated channel mentioned above - their Q&A to grant support allowance is based on the limited support windows on a new product (three months) 8-[
innerbooty wrote:Then, last night, I see that my son has set himself up as an Admin to Manage the Circle network. Obviously he snuck onto my phone and got the passcode. So - I want to reset the passcode, but it seems you can't do that.
Looooool (Sorry 8-/) -> Discussed and explained here in the community befoe: Disney Circle Passcode Reset ... if not, as above.
Just yet another Netgers user (mainly business side) and never touched Circle.
- schumakuJul 06, 2020Guru - Experienced User
-> Contact Circle on NETGEAR Support ... call them up on the number indicated _or_ use the other option:
Want support via other options?
- Visit NETGEAR's support site here
- Under the heading Contact NETGEAR Support, select Get help on my NETGEAR Product.
- Then check the I have a NETGEAR product without a serial number option
- Enter Circle as your product and enter your most recent subscription renewal date for Circle on NETGEAR Premium.
- This process will get you the best contact info for Circle on NETGEAR support.
