Bewong15's avatar
Bewong15
Privacy HSTS Error for child's Chromebook
Hello,
I'm setting up my son's Chromebook for school with a Kids filter in Circle. When he tries to log on in the morning, he gets the following error:
HSTS error
"Your connection is not private," "NET::ERR_CERT_AUTHORITY_INVALID,"
When I try to reboot the computer, it also tells me that the "network may require additional login information" and will not allow me him to log in using ChromeOS.
By removing the device and putting it inot an unfiltered group, he can use the computer, and I typically enable the filter once he's logged in, but the problem happens all over again the next morning.  I cannot accept the certificate because there is no option to do so.
I've searched the forum and it appears that I'm not the only one with this issue, but no resolution has been posted. Does anyone have any suggestions as to how to fix this? I'd prefer not to be the IT help desk every morning.
Thanks so much,
Brian
Hardware Version: RBR40|Orbi AC2200 Tri-band WiFi Router
Firmware Version: V2.5.1.22
ChromeOS Version: 85.0.4183.108 64bit
