jmenear
Jul 09, 2019Follower
R8000 using Disney Circle - unable to remove 'Disney Go' defunct device
Hi,
I have a device on an R8000 that was previously entitled with a Disney Go subscription. The device was destroyed and I'd like to remove it from the Circle app that I use to manage Circle on the Netgear.
When I attempt to remove the device from the app on the page for the device, clicking "Remove Device from Circle", I get the error:
"Remove Device? This device has Circle Go enabled. Please remote it from your Circle Go device list before removing it from your Circle." I no longer have a subscription for the device so I can't do this. Since the device no longer exists I'm not able to remove it from the device itself. Is there a way to manually do so?
- Jamesm34Aspirant
Same problem here if you can come up with some advice. Thanks
- DexterJBNETGEAR Moderator
- Networker25Aspirant
I have the same problem. Sold my old iPhone after factory resetting it but it still shows on Circle and when I try to remove it I get the message: "This device has Circle Go enabled. Please remove it from your Circle Go device list before removing it from your Circle".
How am I supposed to remove this device from the so-called Circle Go Device List? Since I don't have a Circle Go subscription anymore, I would really like to remove all my devices from such a list, provide I can access it. Please help.
