dbwiddis
Mar 24, 2020Star
Orbi RBR50 + Circle frequent DNS failures
I've spent the better part of the past two weeks troubleshooting some DNS issues. They are similar to those reported recently here and probably here and related to similar reports as long as a year ...
- Mar 24, 2020
I've already given up trying to get Orbi to function as a proper Router + Disney + Armor, because it's nothing but trouble. To get Orbi to a stable state, I have to disable practically everything that I could disable, including its internal DNS and DHCP client. I'm currently keeping Orbi for its WiFi capability and delegate all other router functions to DIY pfSense Router Firewall.
I went through a similar pain before I settled on the current setup, which has been holding up quite well during Stay-At-Home order.
- SB8200 -> pfSense -> Orbi AP Mode with static DNS servers and IP address
I settled on pfSense because I need a reliable Gigabit Router with enterprise class DNS resolver, DHCP, Firewall, DNS Filtering, VPN, plus a whole bunch of other features that I don't really need. If you're comfortable with installing pfSense, it's worth a shot.
Smge1lc
Apr 19, 2020Guide
So in the last couple days, I found the orbi routers starting to stall on loading website and access to devices such as fire tv despite having shut down Circle.
So I bit the bullet and upgraded the firmware to the Voxel mod firmware.
I will keep you informed on issues or stability.
Shahab
Apr 20, 2020Apprentice
Netgear finally came back and said that there was an issue with my satellites and they gave me a beta firmware to update the satellites to. Will see how it works out.
Shahab
- FURRYe38Apr 20, 2020Guru - Experienced User
There is newer relase FW available as well:
https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
Let us know how it goes for you. If you continue to see problems, keep in touch with NG support.
Shahab wrote:Netgear finally came back and said that there was an issue with my satellites and they gave me a beta firmware to update the satellites to. Will see how it works out.
Shahab
- ShahabApr 20, 2020Apprentice
For clarification purposes, I was originally having DNS issues because I had Circle enabled. A few weeks back Netgear sent me a replacement router + satellite, I didn't enable Circle on the new equipment and my issue changed to my internet connection (over wi-fi) dropping altogether. I updated firmware on both the router and satellite last night, Netgear wants me to do a factory reset as well, will do that later today and monitor the connection.
Contacting Netgear support is painful, I have been regularly updating my ticket on the support portal but that doesn't generate a callback from Netgear support. Their phone routing system doesn't seem to be working properly, maybe because calls are now routed to people WFH. Whenever I call and put in my case #, it still routes me to the home router support and not the Orbi department, so end up having to be transferred and waiting on hold again.
Shahab
With all the worldy events happening currently, NG has already metioned that there system may see delays and such. You'll need to keep in contact with them or keep in contact with there support ticket system there. "Due to COVID-19 we are still experiencing unusually high call volume. We are continuing to monitor the situation to ensure that the best possible service is provided to our customers. Click here for our top support FAQs"
IF you continue to run in to problems, please post in a new forum post as the main issue with DNS and Circle for this thread has been resolved. So start something new so we dont' confuse your current situation with this new problem your seeing.
If anything contact a forum moderator as well. Blanca_O
Thank you.
Shahab wrote:For clarification purposes, I was originally having DNS issues because I had Circle enabled. A few weeks back Netgear sent me a replacement router + satellite, I didn't enable Circle on the new equipment and my issue changed to my internet connection (over wi-fi) dropping altogether. I updated firmware on both the router and satellite last night, Netgear wants me to do a factory reset as well, will do that later today and monitor the connection.
Shahab
- kgividenApr 20, 2020GuideWhat do you mean dns + circle has been resolved? As far as I know the only thing that works is turning of circle? Which isn’t really a resolution...
For this thread its a temporary solution. Which the OP marked it. Seems to work for now for most Circle problems seen. NG is aware of the CIrcle problem.
For users with current and continue Cirdle problems, please post about anything Circle related over in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thank you.
kgividen wrote:
What do you mean dns + circle has been resolved? As far as I know the only thing that works is turning of circle? Which isn’t really a resolution... - Smge1lcApr 20, 2020GuideChanged the firmware to vexel and it was going well so I added circle back to my mix of functions. Last night and this morning I started getting web loading issues again. Looks like DNS issues.
I shut off circle and reset. Let's see how this works. - FURRYe38Apr 20, 2020Guru - Experienced User
Ya seems to be a Circle problem, even on Voxel FW. I would avoid using it until NG gets it fixed.
I shut off circle and reset. Let's see how this works. - Smge1lcApr 20, 2020Guide
So as my kids were ready to login into their online classes, their laptops had DNS conflics. Interestingly, my desktop server plugged into my main Orbi router is fine. Also, my desktop plugged into my RBK20 is fine.
However, IP6 in 192.168.1.1 is flickering...literally refreshing the screen 1x per second. I just checked and it found its dns.
The kids laptop plugged into the RBS satellite is not getting DNS.
... I am pulling my hair at this point. It was dumb to turn circle on last night.
I would factory reset the RBR and setup from scratch. This time, do not enable Circle or Armor.
I would make a backup configuration to file for safe keeping with Circle not enabled. This will save you time if a reset is needed later on.You'll have to wait until NG gets the Circle issue fixed.
Smge1lc wrote:So as my kids were ready to login into their online classes, their laptops had DNS conflics. Interestingly, my desktop server plugged into my main Orbi router is fine. Also, my desktop plugged into my RBK20 is fine.
- Smge1lcApr 21, 2020Guide
I took your advice and I did a router restore and all is good in the world, so far.
One thing I noticed is that IPV6 is turned off in default. I had mine set to dhcp. This created the issues with all things apple since they're the only ones that use IPV6 vis a vis IPV4.
But that also means that this router does a bad job with IPV6 and the only way to resolve it is to shut down the IOS ability to use IPV6 and downgrade to 4...
Whatever. It works and my kids are surprised their mac and ios phones and working on the home wifi. They tell me they've been using data.
- FURRYe38Apr 21, 2020Guru - Experienced User
Good to hear that the reset helped. I'd keep Circle disabled for now until NG gets this fixed.
Be sure to make a backup configuration to file for safe keeping.
Smge1lc wrote:I took your advice and I did a router restore and all is good in the world, so far.
