Leroyj48's avatar
Leroyj48
reset account info for circle disney
Help! I’ve had to reset my router and manually install the firmware - Circle was working fine before, but I can’t follow the app instructions to pair to circle (no SMS coming through with code). Also as soon as I enable Circle in Genie, internet connection is lost with no DNS. Working fine when Circle not enabled. How can I stop going round in Circles (couldn’t resist!) and set the whole thing up from the beginning?
  • Hi Leroyj48,
    Welcome to the community!
    1. What is the model number and  firmware version of the router?
    2. Have you tried resetting the router?
    3. Have you tried changing your account info and use another number (temporarily) for the code? This link may help.
    Dexter
    Community Team
  • Here's a couple of screen clippings to show what I mean …..
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Leroyj48,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Leroyj48,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
