DatabaseJase
Oct 05, 2020Luminary
Switch between Circle and Netgear Smart Parental Controls
Running firmware 2.5.4.0 and I would like to know if there is a way to switch from Circle to the new Netgear Parental Controls? I'd like to give NPC a try to see how it compares to Circle. Hopefully it is possible to switch back too?
- Christian_RNETGEAR Employee Retired
Hi DatabaseJase,
You should be able to switch back from each Parental Control.
Christian
- DatabaseJaseLuminary
Thank you for the response which is useful but now I need to know how to do that. I'm reluctant to disable Circle until I know I can activate Netgear Smart Parental Controls.
Hi DatabaseJase,
You will need to update to the the firmware version below to have access to smart parental controls.
https://kb.netgear.com/000062320/RBR50-RBS50-Firmware-Version-2-7-0-70
Christian
