Noche
Aug 08, 2019Follower
The R6080 has disney circle?
Hello, before buying the R6080 router I would like to know if it is compatible with disney circle. How is the system I have to buy another electronic device apart from the router? Or is the router enough? It should be noted that I live in Argentina and I can not buy outside my country. Thank you very much in advance. Best regards.
1 Reply
- DexterJBNETGEAR Moderator
Hi Noche, welcome to the community! You can check the link below for routers that do support the Circle feature.
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Dexter
