JJANDCLW
Feb 26, 2019Tutor
Unable to access router login.net after installing Disney Circle
Hi all. Can anyone explain to me why I am no longer able to access the router login.net webpage after setting up Disney Circle on my device? I have assigned my main PC to the “unmanaged device” group,...
DexterJB
Feb 27, 2019NETGEAR Moderator
Hi JJANDCLW,
Welcome to the community!
1. What is the firmware version of the router?
2. Does the issue persist when using another browser and/or device (under a different profile)?
3. Does it work when using the router IP address?
Dexter
Community Team
JJANDCLW
Mar 01, 2019Tutor
Hi Dexter. Thanks for responding.
1. What is the firmware version of the router? Latest firmware, to best of my knowledge, according to my device. That is V1.0.9.64_10.2.64.
2. Does the issue persist when using another browser and/or device (under a different profile)? Interestingly, no. I just discovered by accident a couple of days ago that I can successfully log into routerlogin.net (Safari or Chrome) using my iPad, which is assigned to my Circle profile (the same Circle profile as my PC). It only seems to be blocked (incorrectly) in Edge, Chrome, and IE11 on the Win 10 PC.
3. Does it work when using the router IP address? Incredibly no. It only gets blocked when using routerlogin.net on my PC. If I use IP address, on any browser, I get in successfully. It can't be a clumsy block on routerlogin.net at the Circle end because I can use that on the iPad. But only routerlogin.net specifically is blocked by router on PC. It's a mystery to me. Maybe the browser on iPad is sending something different to gateway then PC browser - but both devices are on the same Circle profile.
Frnakly, for the money Circle with Disney charges, I (as a user) shouldn't have to waste my time wondering and troubleshooting. That said, if it's a just a problem unique to me, I obviously can't hold them responsible.
Much appreciated.
- DexterJBMar 03, 2019NETGEAR Moderator
You can try allowing the routerlogin.net under History if it shows up there and check if it makes a difference.
Dexter
Community Team
