jjpank
Sep 02, 2020Tutor
Why No Circle for RBR750 or other Wifi6 Routers??
I've had my RBR750 for months now, and there still is no word on an implementation of the Circle app for it. It was an expensive router, and i thought it would come with that feature right out of th...
CMorlan
Sep 12, 2020Star
I just received my Orbi Ultra-Performance Mesh WiFi System - AX6000 - 2 pack (RBK852) and am astounded that there are no parental controls at all. The website is very misleading on this, it makes it look like Circle is included on the entire Orbi line.
Looking into this issue through the forums shows it's a long standing issue with the AX#### series, with no clear response from Netgear as to if/when it will be added as of 9/12/2020.
- When will AX6000 get Circle parental controls?
- Need to add Circle to AX6000 / RBK850!!
- Why No Circle for RBR750 or other Wifi6 Routers??
- Does the newer Orbi wi-fi 6 router have parental controls yet (eg. Disney Circle)?
What an incredible let-down. There should be a huge, blinking warning on the AX product and order pages that says NO PARENTAL CONTROLS INCLUDED. Anything less is incredibly misleading.
Very disappointed in Netgear. I'm returning this immediately.
- FURRYe38Aug 13, 2021Guru - Experienced User
