CaptZador's avatar
CaptZador
2014 Router update
Can the R 7000 from 2014 still be updated? And is the Nighthawk app Useable on windows 10 with this router?
  • schumaku's avatar
    schumaku
    Firmware updates are still made available for the R7000 -> https://www.netgear.com/support/product/R7000.aspx
    There is no Nighthawk App neither for Windows nor for MacOS - you can continue using the Genie program, for Live Parental Control it's even required. And yes, this Genie for Windows program can run on Windows 10.
    • CaptZador's avatar
      CaptZador
      Thank you very much for all of your help. I did load a zipped update file to my windows 10, but this machine has no ethernet connection for the older ethernet cables. Any suggestions. was hoping that I could run the update wirelessly to the R 7000 router.
      • schumaku's avatar
        schumaku
        So what does stop you from doing the update via the wireless connection? USB 2.0 to Fast Ethernet and USB 3.x to Gigabit Ethernet adapters are in the market for a few dollars if it has to be a wired connection.
        The App would do the very same, or do you have Ethernet adapters for your mobile devices?
