Jawnoble
Nov 07, 2017Aspirant
34 character system generated admin username for R7000
I ran through the set up program I got . xxxxxx is where I've replaced the actual text , so I'm not broadcasting my passwords. But Look at the Admin Username. ! Trust me I did not create this. ...
William10a
Nov 07, 2017Master
Can you log into the router via a wired lan connection then you could access the routers gui without using the mobile device. Are you the the admin users name you said the devices has is not used by the device and not the router.
- JawnobleNov 07, 2017Aspirant
Yes I can login in through a broswer, but I would like to use the app. The app's login screen won't allow the user name to be changed., so i can't login with a name other thatn admin.
