Jawnoble
Nov 07, 2017Aspirant
34 character system generated admin username for R7000
I ran through the set up program I got . xxxxxx is where I've replaced the actual text , so I'm not broadcasting my passwords. But Look at the Admin Username. ! Trust me I did not create this. ...
William10a
Nov 07, 2017Master
Can you log into the router via a wired lan connection then you could access the routers gui without using the mobile device. Are you the the admin users name you said the devices has is not used by the device and not the router.
Jawnoble
Yes I can login in through a broswer, but I would like to use the app. The app's login screen won't allow the user name to be changed., so i can't login with a name other thatn admin.
- DexterJBNov 27, 2017NETGEAR Moderator
Hi Jawnoble,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
Dexter
Community Team
- JawnobleNov 27, 2017Aspirant
Hi Dexter,
firmware is V1.0.9.12_1.2.23
I've rebooted, but not reset. How do I do that?
Thanks, Jon
- DexterJBNov 29, 2017NETGEAR Moderator
Hi Jawnoble,
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
