Jawnoble
Nov 07, 2017Aspirant
34 character system generated admin username for R7000
I ran through the set up program I got . xxxxxx is where I've replaced the actual text , so I'm not broadcasting my passwords. But Look at the Admin Username. ! Trust me I did not create this. ...
Jawnoble
Yes I can login in through a broswer, but I would like to use the app. The app's login screen won't allow the user name to be changed., so i can't login with a name other thatn admin.
DexterJB
Nov 27, 2017NETGEAR Moderator
Hi Jawnoble,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
Dexter
Community Team
- JawnobleNov 27, 2017Aspirant
Hi Dexter,
firmware is V1.0.9.12_1.2.23
I've rebooted, but not reset. How do I do that?
Thanks, Jon
- DexterJBNov 29, 2017NETGEAR Moderator
Hi Jawnoble,
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- DexterJBJan 22, 2018NETGEAR Moderator
Hi Jawnoble,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- JawnobleJan 22, 2018Aspirant
Hi Dexter, thansk for the folow up. Username went back to admin after a factory reset. Everything back to normal. Thanks.
