MaryAnnB
Oct 15, 2017Aspirant
Airprint setup
When I try to set up my printer with the Airprint tab it tells me to have Itunes and Adobe reader installed and then refreshed. I have done that, installed most recent firmware, rebooted and that mes...
MaryAnnB
As a side note, I just had the computer upgraded to Windows 10 from Vista. I was able to use the Airprint function at tht time. Since the upgrade the error message keeps showing even though I istalled Itunes and Adobe Reader
