gbodie
Aug 27, 2025Aspirant
Alternative to the Nighthawk App?
Is there one? Can I connect my laptop to the Ethernet port and use an HTTP or SSH or something connection to setup my AX1600? I have spent hours trying to get the Android app to do it and, from looki...
Aug 28, 2025Guru - Experienced User
If this is a router, then try this? https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
