WanderingAV
Oct 31, 2021Aspirant
Anywhere Access -- Something Went Wrong -- This Netgear device is already regiatered with another ac
I've seen other posts about this, but haven't seen a solution. I have a R9000. The Nighthawk app works fine when I'm connected locally. But I want to enable Anywhere Access, and run into an error about it already being registered to another account..
I've had the router for a couple years. I only have this one account. With travel getting started again, I wanted to make sure this was enabled, and it can't / won't. Is there anyway to get this reset?
I'm running Nighthawk version 2.12.0.1770 on an android. I've already tried uninstalling and reinstalling it. The R9000 is on the latest firmware as well (v1.0.5.38)
Have you tried a full factory reset and setup from scratch on the router using a wired PC and web browser.
Than after your router is setup log in to the router using the NH app?
You may need to contact NG support for additional help and information on this.
- WanderingAVAspirant
Thanks for the suggestion.
I haven't tried the factory reset route yet, just because of the hassle factor. But my suspicion is that if this was a setting stored in the router itself, then there'd be a way to configure it in the routerlogin.net GUI. But there's not, and since the Nighthawk app requires me to log into the NG servers (before I can log into the router itself) I suspect its something on the NG side.
I'll go the factory reset route as a last resort / try anything approach, but was hoping someone who'd successfully solved it could point the way.
If there's a way to contact NG support for products that are out of warranty (without paying for premium help) I'd try that too. But the support page just points to "ask the community"
Ya something maybe incorrect on in the routers config. Why a reset and a clean setup from scratch with a wired PC and web browser first. Then connect the NH app locally while at home. The app should have a Anywhere Access setting under the left side menu listing using the top left hand corner icon, then down to Settings. If thats enabled, then you should be able to access the router from a remote location outside of the home.
- Boeing787xInitiateIn my situation , the issue preventing me from enabling anywhere access on the night hawk was iCloud relay on my iPhone. Once I disabled it temporarily, I was able to turn on anywhere access.
