JLeon's avatar
JLeon
Attached Devices / Network Map
Hi, I recently upgraded to the latest router firmware (V1.0.2.32) and then noticed my attached devices (and network map devices on genie app) are missing.  Anyone else experiencing the same issue?
JLeon
6/10/2017 @ 6:41AM PT
  • Hi JLeon,
    Please make sure you do a factory reset after updating the router's firmware.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi JLeon,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi JLeon,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
