estowers
Oct 10, 2017Aspirant
but it IIIIIISSSSSSSSSSSSSS supported c'mon!
so i keep getting this garbage although it used to work and since i read both security advisory articles and it swears to god mine isnt affected.......wtf
estowers
Oct 11, 2017Aspirant
so just read in troubleshooting guy has almost same problem but his is R???? router and so i dunno that his solution works for mine, this is my main computer runs everything so accessing routerlogin.net or on an apple app isnt acceptble. that phone is crap filled with virus and there no support for loyal long time cuatoer unless i buy support? what horrible lack of customer service. **bleep** it may as well buy competitor router and start over with a helpfull company this is bull**bleep**
- michaelkenwardOct 11, 2017Guru - Experienced User
estowers wrote:
...accessing routerlogin.net .... isnt acceptble.
What makes you say that?
Routerlogin is easier and safer than using whatever it is you are trying to use now.
routerlogin.net is the browser's way of getting at the internal controls for the modem/router. It is not some dodgy Internet website. Whether you use a browser or the desktop genie app, the result is the same. It gets you into the controls.
Another way to access your device is to find its IP address – in Windows you can use ipconfig – and then use the browser to reach that IP address.
You can also feed that IP address manually into the window from the desktop genie that you have pictured. On which, you can get better screen shots if you use Alt + Print Screen. Then you just get the topmost window without the surrounding junk.
You might also want to check that you have the latest version of the desktop genie:
genie Landing Page | Apps | Discover | Home | NETGEAR
Oh, and if you are trying to get at the modem using wifi, be careful when you come to update the firmware. A wired link is more reliable and less likely to fail in the middle of the process.
- PorkmanOct 19, 2017Aspirant
I'm getting the same error message as OP. This came about after the latest firmware upgrade today. I can't tell you the firmware version as I can no longer access the router with Genie, IP, or http://www.routerlogin.net. Router works fine, just cn not get into it. Any ideas?
- PorkmanOct 20, 2017Aspirant
Corrected my issue by doing a reset. Thought I'd probably brick it but it wasn't doing me any good with not being able to get into the router's settings. Much to my surprise, the router came back to life. Had to reenter all my info but at least it works as a router still and I can now get into the settings. Will think twice about doing another netgeat firmware update.
