randomPst
May 15, 2021Initiate
C7800, can’t connect to Nighthawk App
Just bought this cable modem/router combo and am having trouble with the Nighthawk app on iOS. It keeps asking me to update firmware but it’s already running latest version.
1 Reply
randomPst wrote:
It keeps asking me to update firmware but it’s already running latest version.Ah. That one. The message is nonsense. You cannot update the firmware on a cable modem/router. That is down to the ISP.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
There's a bug of some sort that you can safely ignore:
Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
You will also find more on this in the section for your hardware.
This one , for example:
