jtstarr17's avatar
jtstarr17
Can’t get app to connect to router
I got a new phone and downloaded the NETGEAR app but it can’t connect to the router. So I can’t set up the app to work? I think it is trying to connect to the default network name and password instead of the one I changed it to after originally setting it up.
  • plemans's avatar
    Do you have the phone and the router's wifi?
    What modem are you using?
    • jtstarr17's avatar
      jtstarr17
      I have my phone, home security panel and laptop that all connect to WIFI off the router. But when I try to set up the app it says it can't connect to the router. It originally connected when I first set up the app on my old phone when I first got the router.
      I have never had a modem. I have just been running off wifi from the router plugged into the wall.
      • michaelkenward's avatar
        michaelkenward
        plemans asked about the modem. You replied
        "the router plugged into the wall."
        Unfortunately, that is ambiguous. It doesn't tell us how the internet gets to you.
        Is this a fibre optic service with an "ONT" socket on the wall? Or is it, for example, an apartment with an Ethernet service?
