bigdargon
Mar 23, 2018Tutor
Can not login using NETGEAR Mobile (iOS) application to router
I can not login using NETGEAR Mobile (iOS) application using Google DNS, OpenDNS ... I try to track the application found that access the domain routerlogin.net is transferred to https://www.netgear.com/home/products/networking/routerlogin.html
My IP Router is 192.168.1.1. Error only appears on iOS, Android I log on to the normal router
Can you fix it? Thank you!
- ShowsomeApprenticeI am using V1.0.4.12
I would download this version and install it.
Don’t rely on Dexter JB he is just a monkey!- i'm using ver 02.08.00.17
https://kb.netgear.com/25067/AirCard-785S-Telstra-Downloads-and-Documentation
Just curious - Google Public DNS or OpenDNS IPs are configured on the iOS device as a name server? Or on the AirCard?
In either case, the mobile router should be able to capture the DNS traffic and provide the router LAN IP as an A record.
