andrelerouxcpt
Nov 23, 2017Aspirant
Cannot configure parental controls
I have recently purchased the Nighthawk R7800 and am currently waiting on the local provider to install fibre (FTTH) access. While waiting in the fibre install I thought I would read up on the confi...
michaelkenward
Nov 24, 2017Guru - Experienced User
andrelerouxcpt wrote:
I then stumble on the issue that you are unable to connect to OpenDNS (login failed) and it seems that even in the latest posts on this community Netgear has still not sorted the issue.
Not everyone has this problem. I don't. You won't know if you are affected until you have your network up and running.
Can you access this site:
https://netgear.opendns.com/sign_in.php
