Bourmatnov's avatar
Bourmatnov
Follower
Aug 07, 2019
Cannot LOGON to Netgear Nighthawk Iphone App
I utilize the Nighthawk iPhone app to remotely manage my router.  I forgot the password and reset it using the forgot password button on the app. However, I have not been able to logon to the App. It says "An Error Has Occurred - Try again"  I know I am using teh correct credentials because I am able to logon to the Netgear site with the same credentials!  Is it possible I have bene blocked by Netgear?  The company doesn't seem to offer any logon help in front of the paywall.
Thanks,
Paul
  • schumaku's avatar
    schumaku
    Hi Paul,
    A little bit thin - please provide at least the router model, the firmware version, and the App version.
    Just wild guessing here: I suspect that there is a dependency between the router registered for remote administration (by App) and the password - and that after the change of the [My]Netgear account password the router can no longer link up with the cloud anymore, and can't be reached therefore.
    A test worth trying would be to disable and enable the remote administration - while being connected to the local [W]LAN.
    They think their products don't require such basic support ... my wild unqualified and unique view from the Swiss mountains .... ups. I'm not allowed to say more - because I had promised to be nice to Netgear.
    -Kurt.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi RayCara, may we know what specific issue are you encountering with the Nighthawk app? Also, what steps have you tried so far?
      Dexter
      • RayCara's avatar
        RayCara
        I was having issues with my router, not loading certain websites (which worked fine the other day) over some security issues that another router (non Netgear) handled fine.
        So I used the paper clip trick to re-set the modem.
        After some time passed and the modem was up, tried to use the iPhone app to change some of the setting of the router, and the phone didn't want to connect and kept asking me for a password and wasn't taking the default password for Admin or the password on the back of router, or my Netgear account name and password.
         Although my Netgear account name and password get me into the web site from my browser.
         I even reset the password, from the web site and it didn’t help.
        I tried deleting and re-downloading the app from my iPhone, but it's still stuck at the “Netgear, One Accout, Any App” screen and not accepting my credentials.
         I gave up and used a browser on my Mac to get into the router and change the name and password etc.
        And yes... The iPhone on the Netgear router's wireless network. All my internet-using apps are running fine on the phone. And this app used to work fine.
        Thoughts?
  • I have the same issue. I reset my password and I'm able to log into the account via the desktop computer but can log into my Nighthawk app on iPhone iOS app .
