tz0001
Sep 20, 2016Aspirant
cannot update firmware DGND3700v2
I'm on Firmware Version V1.1.00.23_1.00.23, trying to get to .26. If I use the 'Wizard' it find the update, says it's installing it, then towards the finish brings up the HTTP authentication dia...
Retired_Member
Sep 20, 2016Which version of .26 did you download? There are two. It may be a zip file which needs to be unzipped before installing.
tz0001
Sep 21, 2016Aspirant
Thanks Searay
For the manual update, I chose the non-North America file from here https://www.netgear.com/support/product/DGND3700v2.aspx?cid=wmt_netgear_organic#download
Yes, I do have a non-US version :smileyhappy:
It was a zip file, and I unzipped it. If you try to load a zip file you get an error, which I didn't receive. It appears to upload and install normally, but the installed firmware version never updates.
For the auto update, there is no choice to make and I'm getting the same result.
If you've got any other suggestions on things to check I'd really appreciate it!
