Firmware
25 TopicsCan't connect to nighthawk app - Spectrum Internet - AC1600 Model C6250
Just moved and got my router and internet set up (AC1600 WiFi Model C6250; Spectrum Internet). In trying to connect to the nighthawk app it tells me my firmware is out of date. When I go to routerlogin is shows V1.01.26 and doesn't give me a way to update it. On the netgear website it says this the latest Spectrum approved firmware. Anyone know I can can get the nighthawk app to work? Thanks!1.7KViews0likes2CommentsC6220 Router Needs Firmware Update According to App
Wifi disconnects every 20 min. According the the nighthawk app, my router/modem needs an update. However, when I finally log into genie / www.routerlogin , I go to advanced and there’s no update. It even says my internet connection is good and everything in the green. What’s further frustrating is I bought Ethernet cables and they connect, yet wifi still goes out. When I called NETGEAR (literally so unhelpful) they told me I needed a “little firmware update” (what does this mean I have 1.01.26) but when I queried about my circumstance above, they told me to enroll in a 140 dollar program because there’s more than can see on their end. Gross. Please help! Anything if possible!1.5KViews0likes2Commentsnighthawk mesh 6 app for MacBook
Are there any app downloads for MacBooks from NetGear? I only saw apps for IPhone and IPad. Or should i just use the router address to configure my wifi. Which is better and more secure? Finding unknown devices on my internet under attached devices even though Acces control turned on and Block new devices are checked.1.1KViews0likes1CommentCan’t login to Nighthawk app after firmware update
R7900P Router Firmware v1.4.1.68_1.3.28 Nighthawk App v2.9.5.14 iOS 14.4.2 I updated firmware yesterday and have not been able to sign in to Nighthawk app ever since. I’ve tried everything I can think of. Deleted app and reinstalled. Even changed router name and password back to factory specs. No dice. Routerlogin.net (192.168.1.1) works fine on Windows 10. Any help would be greatly appreciated! Thanks!3KViews1like4CommentsReadyCLOUD not showing any attached drives in R7000
Hi, I've got a R7000 router with the latest firmware version (R7000-V1.0.9.32_10.2.34.zip) and my drives aren't shown at ReadyCloud through web interface. I've already tried everything I could imagine like: 1 - Reseting the router and configuring everything manually (not restoring config); 2 - Flashing the latest firmware again; 3 - Unregistering the router in ReadyCloud and registering again and so on. For me having access to my router through web interface is really important, because, besides being simple, I can also access my files and upload new ones from my work without installing any third party software. Can I do anything to solve this? I've noticed this issue has been constantly reported by many users in other posts. Maybe, it is firmware related and Netgear should solve it with an update.5.2KViews0likes10CommentsCannot update firmware on R6400 thru NIGHTHAWK app
After receiving email to update firmware, installed the NIGHTHAWK app. Updated my Netgear info on computer. Thru the app can only get to the page to visit routerlogin.net. Once I click on that button, I cannot log into routerlogin.net. Tried multiple user name and passwords. Cannot update firmware. Any suggestions?3.9KViews0likes4CommentsUpdated firmware and now R7000 is not supported?
Received an email from netgear saying there was a security update in the latest firmware and I needed to download the nighthawk app and update my router. So I did. The app hung on my iphone. So I left my iphone running overnight. In the morning, still hung. So I power cycled the router and I got rid of that nighthawk app. Genie was working fine, I don't know why I'm supposed to use yet another app. So I don't know if the update was successful or not because now I can't log into my router over wifi to check the firmware version. I've got connectivity, I'm connected via wifi, but Genie says the router is unsupported. If I bring up genie, everything looks good until I hit router settings, then it won't take my login and says my router isn't supported. Sorry for the redundancy. But hey, this nighthawk app is redundant too, so **bleep** for tat I guess.2.1KViews0likes1CommentNightHawk R8000 firmware Attached device list
Just update to the latest and greatest firmware for the R8000, but now the Genie app fails to do much like update the network map and the device listing cannot be updated directly from the router. I have reset the router via both the hardware reset and via the web interface. Same problem. Ideas? A firmware miss? I've also noticed the Speedtest little animation is not there anymore either. Is this all in the name of the Disney stuff netgear loaded? Please return functionality to the router!Solved4.5KViews1like5CommentsR7000 after firmware upgrade, Bedtime function in Circle doesn’t function properly anymore.
I have just updated my Netgear R7000 firmware to V1.0.9.26_10.2.31. I have also enabled the Circle(parental guidance) on my Netgear router with bedtime function turned for my kid. After the firmware upgrade, my kid's profile seems acting very strange, such as it immediately said all the time has been all used up and it keeps saying it has been passed his bedtime. I have recreated my kid's user profile from my iPhone Circle application but still, the bedtime isn't working properly. Can someone help, please? Is this firmware not compatible with Circle on my Netgear router?1.9KViews0likes4Comments
