needmywifiback's avatar
Jun 30, 2022
C6220 Router Needs Firmware Update According to App
Wifi disconnects every 20 min. According the the nighthawk app, my router/modem needs an update. However, when I finally log into genie / www.routerlogin , I go to advanced and there’s no update. It even says my internet connection is good and everything in the green.
What’s further frustrating is I bought Ethernet cables and they connect, yet wifi still goes out. When I called NETGEAR (literally so unhelpful) they told me I needed a “little firmware update” (what does this mean I have 1.01.26) but when I queried about my circumstance above, they told me to enroll in a 140 dollar program because there’s more than can see on their end. Gross.
Please help! Anything if possible!
  • plemans's avatar
    A couple things.
    1. The C6220 is a modem/router combo device. Its not user updateable. Its pushed from the ISP when they provision it.
    You can check the version your on to the current isp ones.
    https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
    Sometimes a factory reset and reinstall will pull a new provisioning from the ISP.
    2. Many times, connection issues are related to your line connection from the isp. Do you have a screensnip of the cable connections page and event logs?
    3. Try logging in through the browser and not the app. When the app gets caught in that loop for 'app update', it can be a pita.
  • michaelkenward's avatar
    michaelkenward
    There was a  bug in the iOS app that threw up that message even though it is meaningless for most cable modem/routers.
    Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
    Note the Netgear response:
    Re: Nighthawk app same "firmware not updated" when... - NETGEAR Communities
    Does that ring any bells?
    I doubt if that was Netgear. Did you ring a number you found on a web search? If so, it was probably one of those scam merchants that buys ad space on Google.
    Finally, while many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Cable Modems & Routers
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
