tz0001
Sep 20, 2016Aspirant
cannot update firmware DGND3700v2
I'm on Firmware Version V1.1.00.23_1.00.23, trying to get to .26. If I use the 'Wizard' it find the update, says it's installing it, then towards the finish brings up the HTTP authentication dia...
tz0001
Sep 21, 2016Aspirant
Thanks Searay
For the manual update, I chose the non-North America file from here https://www.netgear.com/support/product/DGND3700v2.aspx?cid=wmt_netgear_organic#download
Yes, I do have a non-US version :smileyhappy:
It was a zip file, and I unzipped it. If you try to load a zip file you get an error, which I didn't receive. It appears to upload and install normally, but the installed firmware version never updates.
For the auto update, there is no choice to make and I'm getting the same result.
If you've got any other suggestions on things to check I'd really appreciate it!
Retired_Member
Sep 21, 2016You're Welcome
You might leave well enough alone, Meaning it's working and everything going forward is a ____ shoot. Reset to factory defaults and try again if you insists.
Good Luck!
- tz0001Sep 21, 2016Aspirant
Thanks Searay. Was hoping to avoid a factory reset but if no-one else has any other experience with this issue it might be the only option.
- Retired_MemberSep 21, 2016
What does the new version offer that's worth all the what ifs?
There's a security issue that was patched in .24 which I'm keen to get. Version .26 itself isn't a big deal for me. Would also like to be able to upgrade to anything beyond .26 if there's an issue that affects me.
