eww2018
Jul 06, 2018Follower
Cannot update firmware on R6400 thru NIGHTHAWK app
After receiving email to update firmware, installed the NIGHTHAWK app. Updated my Netgear info on computer. Thru the app can only get to the page to visit routerlogin.net. Once I click on that button...
michaelkenward
Jul 16, 2018Guru - Experienced User
eww2018 wrote:
After receiving email to update firmware, installed the NIGHTHAWK app. Updated my Netgear info on computer. Thru the app can only get to the page to visit routerlogin.net. Once I click on that button, I cannot log into routerlogin.net. Tried multiple user name and passwords. Cannot update firmware. Any suggestions?
Kind of hard to follow what is going on there.
What does "Updated my Netgear info on computer" mean?
And what does this bit mean "Once I click on that button, I cannot log into routerlogin.net."
What button? What happened when you tried? "cannot log into" means nothing because there are many ways on which people cannot log in.
And what NIGHTHAWK app are you using? iThing? Android?
Can you approach your R6400 with a web browser?
There is a manual for the R6400 somewhere at the end of this link:
>>> R6400 | Product | Support | NETGEAR <<<
This has a section on how to update the firmware.
- RoyisnotbatmanJul 17, 2018Initiate
I skipped the Nighthawk step, used the username and password on the bottom of my R6400 to logon to routerlogin.net and updated the firmware. There is an option to authorize future updates to occur automatically. Think that's it for this issue.
- michaelkenwardJul 18, 2018Guru - Experienced User
That's the way to do it. More reliable than apps, especially if you do it with a wired connection to the router.
Many people disable that because automatic updates can break their systems.
