wxman319
Nov 10, 2016Follower
Can't block a device
Hello!
Does anyone know why I can't block one of the devices on my Netgear Genie network map?
All the other connected devices have the option to block. I have access control turned on.
But one device just gives me the details and no option to block it and I don't recognize the device.
Thank You,
wxman319
What device is this?
- Retired_Member
Thank You,wxman319
Login to router and check attached Device List
- jjdeleon315Aspirant
Hello,
I had the same issue and when I applied High Restriction on the device it then allowed me to block the device completely. Just modify and apply some parental controls(namely HIGH) then it will allow you to completely block the device.
Hope it works for you!
