PJD1978
Mar 21, 2023Tutor
Can't connect through NH App
I'm not able to connect to the router via the Nighthawk app (android version 2.24.0.2733). While connected to the network, I can login through routerlogin.net and by IP address of 192.168.1.1. But whe...
michaelkenward
Mar 22, 2023Guru - Experienced User
Which router is that? Netgear has made many over the years. And the firmware numbers tell us nothing about the model number.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
