ekantnemo
Nov 20, 2022Follower
Can't connect with Nighthawk app anymore
I was able to connect my smartphone to the router using the Nighthawk app but now I can't anymore. It says "Logon timeout, try again". My router is R7200. The app used to work fine awhile ago.
Kitsap
Nov 21, 2022Master
ekantnemo wrote:I was able to connect my smartphone to the router using the Nighthawk app but now I can't anymore. It says "Logon timeout, try again". My router is R7200. The app used to work fine awhile ago.
There is a special section of the Netgear Community that deals with the Nighthawk Application.
Try posting your question here: https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Nov 21, 2022Guru - Experienced User
