Nevet
Oct 19, 2026Follower
Can't Log In on Small Screen
On a small mobile device (iPhone 13 Mini), the Password field is obscured by the Log in button and completely inaccessible! See attached screenshot.
Something to submit a bug report to see if NG will fix it. iPhone 13 is several years old not may not be supportive.
Can shake the phone will the app is running and submit a bug report thru the app.
Otherwise if you are setting up a new router, use it's WEB page UI to set it up with a ethernet PC. PC can be wireless as well:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
1 Reply
